i noticed on a friends 90 accord that there was a little black box mounted behind the headlight and beside the battery that has a plug and a vacuum line running to the throttle body what is it and what does it do. reason i ask is because i have a 90 accord as well and i dont have that but the wire is there to plug it in. thanks
little black box?
I have a 90 lx and i have the box too ... any guesses why?R.I.P. 6-10-07
(\__/)
(O.o )
My Rotor DIY
I'm not perfect i will make mistakes if i do just point it out to me
That box its a control for starting the car in cold weather, if you look at what its connected to you will see a section of the intake that draws from inside the engine compartment. When the motor is very cold that valve opens and alows the motor to draw warmer air from near the engine rather than from the fender well. I would never leave a vacume tube open. Leave that box alone and just remove the interior piping. There is a sensor on that part or the part it connects to. So if you dont know what it does I would leave it alone..
This part is in a bad spot... I broke the vacume connection to it when i was installing a CAI. I ended up drilling out a small hole on the box to reseat the connection because it kept braking off when i just used superglue. Dont leave vacume tubes open, that hissing sound means your drawing air into your motor without a filter of any kind on it.I cant Slam further. The ground refuses to get any lower.
The intake air control system decreases air intake noise.
When the engine speed is below 3,500 rpm, the ECU supplies current to the intake control solenoid valve. This opens the solenoid valve sending intake manifold vacuum to the intake control diaphragm.
Basically it cuts off some of the air for the intake to use in order to quiet down the engine. From a performance point of view, remove it.
Remove it, be sure the plunger it controls is stuck in the up (open) position. Or instead of removing it entirely, just disconnect the electrical connector.
I don't know if it is causing your problem.
with 260k on her
