Wierd Squeak Noise
    Wierd Squeak Noise
    Ok when I start driving my car in first gear my car jerks a little and i hear a squeak noise coming from my front passenger wheel, Does anybody know what this is? Its very annoying, my car is too clean for the squeak noise and i hate.. Could it be my shocks, axles or what? please help!!
    axles.
    DEFJAM
    MY RIDE ON CB7 DEFJAM on 93
      axles tend to click not squeak, im gunna lean twards struts or wheel bearings, but i need more info, when turning, hitting bumps, when does this happen ( my buddy had one that squeaked and we thought it was a strut, he got off the freeway and his wheel tried to fly off the pas. side. it was held on by the lower balljoint and the tie rod end
      New cb, new start
        As mentioned by 91h22cb7lx give us a lil more information. Prob one of your bushings and such going out around your suspension area. A wheel bearing would be a constant humm as you picked up speed and it would increase the faster you went.
          most prob balljoints, but like everyone else stated, more info
          Not my fault my dick only fits magnums.
          Why drink and drive when you can smoke and FLY?
            I had a squeak in my front driver side wheel for the longest time. I finally noticed some polished steel in the sway bar link. One of the four sway bar link bushings on that side was missing and was allowing the sway bar to rub on the link kit bolt.
            I suggest you check there, not difficult to replace at all.
            MY RIDE
              Due to my bad motor mount, my car shakes a little on start off.. which causes the squeak noise on the passenger side.. i have a manual so...
              what other info do you guys need..
