Direct Swap: f22b AND h23a?????
    Hello guys, I'm new to the forms! I've 'lurked' around long enough and learned a ton. I recently purchased a *clean* 92 cb7 5-speed. I have to say after driving Civics for most of my Honda ownership, it's a nice change.
    However, I have a few questions about swaps, and correct me if I'm wrong.
    The F22b is a direct bolt on, everything plugs in right, no "big deal."
    The H23a (usdm non vtec) = F22b.....
    So am I correct in thinking that an H23a would be a no hassle direct bolt on as well? Or am I better off just finding a good F22b? I know the H22a is popular and good swap, but I'm looking for something with the least amount of work is involved, because I'm not going all out for performance, just a boost needed for the drop of $$$$$$ into suspension. MMMM handling.
    Any help would be appreciated!
    yes, the f22b is a direct bolt on into your CB7. The jdm f22b and usdm h23a are essentially the same motor.
    2010 Toyota Camry LE 2.5L - the most boring car ever
    2002 Impreza WRX - TD05-16G, 178K miles, 30mpg hwy
    1993 Accord SE - RIP 10/2000-07/2013
      running 3 wires is a lot of work? everything else is the same.
      if your going to spend money on an engine, just get the H22, you will probably never regret it
        As mentioned wiring up 4 wires isnt bad. H23 requires a knock sensor to be wired.
