EGR wiring
    EGR wiring
    I just got done swapping my car from auto to 5speed and swapping in an h22a and now after i drive for awhile, i get a check engine light its cel code #12 which i have been told is egr. My Egr is not wired up because havent had time, and i dont know what color the wires are on my 93 honda accord lx automatic harness. Also vtec has not been engaging, it doesnt show any check engine lights for vtec or knock sensor, everything is wired properly as far as vtec and knock sensor go. Im wondering if the solinoid or the ecu is bad and also if the egr will make vtec not engage.
    H22-T FTW!!!
    I thought u were suppose to switch the egr valve from the f22
      plug switch
      you can just switch the plugs if you have a wiring diagram, and my h22a egr is in better shape so ...
      H22-T FTW!!!
        wait so you should just use your f22 egr valve so you don't have to change pigtail plug ? i ask cuz i'm in process of swapping soon (gathering all i can to make it a two day ordeal, one day labor one day wiring and testing) and once you swap egr from original engine to h22 it's all plug and play it will work and be less of a hassle than cutting original pigtail and replacing with h22 connector?!?!?!???!?????!????!???
        My other ride is your ex-wife
          true
          its true you can just use the f22 egr but i opted to use the one that came with the h22 and switch plugs, my f22 egr if fucked up. Now im trying to get a wiring diagram or something to tell me which wires to match up.
          H22-T FTW!!!
