250whp?
    250whp?
    I' am finally about to turbocharge my cb7!! I want to do it big but I want to start out with a 250whp goal. I need some advice on how I should go about making that 250whp goal of mine. Any advice will be greatly appreciated. Thanks
    Soon to be "The Beast"
    1 the best advice i think would be to do a shit load of research
    you may have already but even if you think your ready most of the time your not
    there’s a lot of things that pop up once you start the project that if your not ready for may make you change your mind...and most of that time that’ll be after you bought a shit load of parts.
    2 its a better idea too start at only at a 200 whp goal
    if your boosting for the first time its a good idea to start out at only 8 psi
    f22s are know to be pretty stable at 8 psi and most likely wont give you many problems
    when everybody catches the turbo bug they wana go big but after doing research they come back down to reality and decide to keep it somewhat simple
    your goal isnt crazy but its still somewhat hard to acheve w/ a stock bottom end. and building your bottom end isnt something you want to get into yet eather
    3 compression test and leak down test the motor before you start. if those things are good you shouldn’t see many problems
    even if you have a shit load of miles
    4 make sure you get it dyno tuned-----its expensive but a must...some go w/ a street tune but 1. you have to know someone thats veryy good at tuning 2.you wont be making all the power you could 3. itl be much easyer to blow the engine
    Old Ride-New Ride
      Thanks for the info, I really appreciate it.
        you'll probably need a turbo in the t3/t04e range. The 50,57, or possibly even the 60 trim would get you there with supporting mods pretty easily at 9-10psi
