odd vss problem...
    odd vss problem...
    hey ive been having some wierd problems with my vss lately and its really starting to bother me, so i was wondering if anyone else has had the same problem, and if so how did they fix it.
    ok, so basically a couple months ago i noticed my vss starting to go, ok no problem, had all the symptoms cc not working, bouncing up and down, so i decided to get a new vss. i hadnt had time to install it, but within the last month things started to get a bit strange. nowadays, the boucning rarely happens, however whenever you foot even touches the brake pedal the speedo drops straight to zero, let go and it comes back up. the cel comes on after a while, spits out a code 17 for the vss, and the car drives like crap. also, when im on the highway the speedo says im doin 160, and im only really doin like 130.
    i kno that it seems like a simple fix since the cel is throwing a 17, however i find it odd that it drops like that when my foot even touches the brake pedal. it seems to be something also wrong with the wiring somewhere, maybe a ground? my mechanic advised me that i should fix the wiring issue, cuz even if i replace the vss it might not full solve the problem and i may have to buy another vss in a little while...
    so my question to u guys is, has anyone seen this? does anyone kno wut it is, or how to fix it? any help is appreciated and thanks for ur time
    no one?
      i had a similar problem to yours, what turned out to be is that the bolt that hold the vss to the tranny was broken, so when i accelerated hard and braked, i guess the vss would jump or something like that, so check that out first
      Members Ride
        wow, that is really good info. good call bro.
        Formerly: sheisanonymous
          yeah make sure everything is tight, when you tight that bolt, to no tighten too much, cause i broke mine, i turned it a little bit with the wrench and snap, i was like shit, so just hand tighten and then tighten very little with the ratchet, and make sure the wire on the connector are still in place
          Members Ride
            ok went out today and checked everything, thanks for the help, and everythings good... im thinking its somehting to do with ground/electrical?
