Dashboard Removal?
    Dashboard Removal?
    i kno theres the 2 screws on each side but i just dont know where the rest of the screws are for sure. lmk
    Maybe one of these will help:
    http://www.cb7tuner.com/vbb/showthre...hboard+removal
    1992 Honda Accord Coupe LX
      1 Disconnect the negative battery cable
      2 Slide the seats back all the way.
      3 Remove the center console.
      4 Remove the knee bolster and lower panel.
      5 Remove the steering column. Observe all precautions for SRS systems.
      6 Disconnect the dash wiring harness from the individual connectors and the fusebox.
      7 Remove the clips securing the carpet and disconnect the antenna lead.
      8 Disconnect the heater control cable and function control cable.
      9 Remove the caps on the side panels of the dashboard.
      10 Remove the clock.
      11 Remove the seven mounting bolts.
      12 With an assistant, lift the dashboard and remove it from the vehicle.
      hope that helps .... if you need somthin else holla
      R.I.P. 6-10-07
      (\__/)
      (O.o )
      My Rotor DIY
      I'm not perfect i will make mistakes if i do just point it out to me
        i forgot to metion that that is the entire dash removale in one pice (sp) if you need componet spisific(sp) instructions (ie radio) just ask and i'll be happy to help
        R.I.P. 6-10-07
        (\__/)
        (O.o )
        My Rotor DIY
          get the haynes manual
          I was looking in my haynes manual and it shows excatly how to remove the dash, go to advance auto parts and buy the book for 10 bucks.
            aiight cool..Thanks a lot
              If you have any more questions or any trouble with it send cp[mike] a PM. He has swapped interiors and stripped CB7's to their bare bones. He may not live to far from you depeding on whereabouts in NY you are. I believe he is in southern NY if I remember correctly. Later
