can belts be changed by amateur > anything tricky ?
    I need to change both belts, anything tricky to doing this by a amateur ?
    Is it as simple as, loose belt , remove them, slip back in the new ones.
    (The 2 rubber belts in engine)
    not really tricky just time consuming and it needs to be done right and double checked. before you start check timing and then proceed. what engine do you have? auto tensioner or manual? you would benefit greatly from purchasing a shop manual , haynes/chilton ok honda shop manual better, better pics more info etc... i have both manuals in pdf. format for the 4th gen accord and prelude if you have h22/h23 engine pm if your interested otherwise ask around some more alot of these guys can help out.
    My other ride is your ex-wife
      thanks for manual, and repsonse too!
        Were you talkin timing or accessory belt?
          I'm guessing he's talking about his accessory belts.
          Midwest car club
          Current rides:
          91 accord lx (5spd)
          92 accord lx (5spd)
          93 accord lx (auto )
            yeah ! accessory belts .... Do i just remove old ones, put in new ones, adjust tensioner bolts all is good ?
            what are the steps and tools needed , quickly ?
              You got it man, just adjust the tension so you can slip the belts off, and slip the new ones on. Its probably gonna take some fooling around with in order to keep your belts from making a little bit of noise. The only way you can really learn is to get in there and mess with it. I wasn't really familiar with the tensioning system that Honda uses, because I'm used to damn Chevy 350's, but I still managed to change my alternator in like an hour a few weeks back... Its not bad. Just fiddle with it, we're here to help if ya get stuck.
              EDIT: For tools, all you should need is pretty much a 10 and 12mm wrenches.
                right on...... that for the info. now i know.....
                it all i need to know for now.......
                thank much guys..
                  Yea you need a 10,12,14mm sockets to take the belts loose and crap. 14 to break the main nut 12 to break the lock nut for the tensioner and the 10 to loosen the tensioner and basically thats that. Be sure to put on the alternator/ac/crank belt first before putting on the PS/crank. Just FYI lol.
                    yea there real esay to change i changed mine when i switched out my alt. you might want to get/barrow one of those belt tension testers cuz if the belt is to tight you'll burn bearings if its to loose you'll squeel like hell and will have to replace the belts a second time
                    note i dont want to scare you or any thing i did mine without the tool i just guess the proper tension the tool is not a required thing
                    R.I.P. 6-10-07
                    (\__/)
                    (O.o )
                    My Rotor DIY
                    I'm not perfect i will make mistakes if i do just point it out to me
                      Poppinbottlez.......
                      ALL BELTS SIMPLE....JUST TAKE YOUR TIME....ITS KINDA COMMEN SENCE....NOW IF YOUR TALKING ABOUT YOUR TIMING BELT AND YOUR NOT TO INTO DOING ENGINE MODS YOURSELF I THINK U SHOULD GET A PROF. TO INSTALL A TIMING BELT....IF U DONT KNOW WHAT YOUR DOING U CAN SCREW UP YOUR TIMING.....NOT GOOD....GOODLUCK
