I think there is a frozen caliper bolt on my Mom's Odyseey. What happens is during the last few moments of braking before stopping, I can hear this sort of grinding noise comng from the left front brakes.
Signs of frozen caliper bolt?
Ii think there are little metal clips on breaks that might make that noise when they are getting low, but if it is like a real hard grinding noise i would get them checked out.Lois: Oh, I haven't been on a college campus in years. Everything seems so different.
Stewie: Really? Perhaps if you laid on your back with your ankles behind your ears that would ring a few bells.
Originally posted by 93cbh22if it were a frozen bolt or pinthat particular pad set would have uneven wear throughout the entire pad surface more likely to be on the majority of one side whether top or bottom bolt/pin
Originally posted by NAiL05Plus the rim will be abnormally hot if the caliper was kinda locked up. We had that happen on a merc MLK320? Something like that one of the SUV turns out the piston was rusted in the housing.
yea and i dont think that it have a grinding noiseR.I.P. 6-10-07
(\__/)
(O.o )
My Rotor DIY
I'm not perfect i will make mistakes if i do just point it out to me
ya...my accord calipre bolt actually froze too...what happens is like the guy said above, it will wear tremendously on one side at a large angle (like 1/4" different from top of pad to bottom). Then it might even wear to the metal of the pad beacuse it is wearing unevenly and not effectively and getting the bottom much faster.
it would be wise to take the calipre off and either get a new bolt or calipre...ideally before the disk is destroyed by the metal on metal braking.
Also, the grinding noise could just be the signal tab running on the disk
Mark
