H22 not starting
    H22 not starting
    sup cb peeps, my cousin also has a cb7 with an h22 swap and its not starting. he bought a new distributer and its not starting he has spark the battery is fine the fuel pump is working I tried adjustig the distributer and nothing is not happening, I want 2 see his car on the road again so could u guys please lend me a helping hand?
    "Cocaine's a hellava drug"
    where's the needle on the gas gauge? jk
    did he work on it recently? was a cold start or a warm start?
      check the ignitor in the dizzy
      new ride
      07 cobalt ss/sc
        make sure u have the firing order correct
        Members Ride
          the engine is turning over but nothin is combusting..
            x2. That can cause a no start.
              okay here are a few things you need to check. check fuel pump, pressure regulator, check battery connection if loose or corroded, check if fuel is reaching fuel injectors, ignition component maybe damp or damaged, check spark plug if correct gap or any damage, check wiring in the starting circuit, recheck if coil is damage or disconnected coil. if everything fails, let us know.
