As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Ignition switch issue
    Ignition switch- What areas of your ride will this affect if it goes bad….
    I think my switch is bad… I thought it was my main relay that was bad at first… I got a replacement for my relay ( New one )… Now I have the same damn problem…. My dash will light up, but not one of my gauges will work. My seatbelts will not slide back when I turn my car on…. And no it’s not the door switch I took a look at that too. Anyone know if my ignition switch is the issue… Thank for your time…..
    My Members Ride Thread ( Do It )
    yeah it has some of the symptons of your ignitiong switch going bad, meaning the harness part of the switch. i had the same problem with a couple of cb's and civic that i worked on
    Members Ride
      So what did you do to fix the issue.... Did you replace the electric part of the switch?
