Does Anyone One know ?
    Does anyone know the purpose of the STARTER SIGNAL FUSE in the driver side fusebox...my seem to not be getting any power and the fuse is still good? Any suggestions?
    Never mind tha Slowprocess...Its more progress...DarkVader
    R.I.P
    90' CB7 project in Progress.....
    F22A
    CAI
    Headers
    EXhaust
    ask ur question? so that means that ur car aint starting right. did u buy the car like that or it just turned off and now it dont start??? whats ur problem with ur car???
    thanx for da sig. DFRHonda
      that is the fuse that link the key ignition to the starter signal so that when u turn ur key it cranks the starter!
        Yes sir, I was driving and it just conked out..... I even went as far as replacing some components, starter, battery, spark plugs etc. and still wont start. So how do I fix this problem? Thankx for the feedback I really appreciate it.
        R.I.P
        F22A
        CAI
        Headers
        EXhaust
          Yea thanks.. Its not getting no power and the fuse is STILL good.. I tested all fuses for power they 're good only this one? Any formulas?
          R.I.P
          F22A
          CAI
          Headers
          EXhaust
            k so u were driving and it died on you? and now does it crank or it cranks but no start?is it getin spark and fuel?
              Common Honda problem: Ignitor failure. You'll be driving along all nice, and the car will act like someone just turned the key off, and while it'll crank and crank, it won't start. So then you let it sit for 15 minutes or so, and it starts back up and goes for a while longer and then shuts off again. Sound familiar? What happens is that the resin that the circuitry of the ignitor is buried in fatigues over time and cracks, which allows the circuits to heat up and expand, and then break, causing the engine to quit due to lack of spark. Then when it cools down a bit, the circuits contract, making contact again, and you're able to start the car and drive 'till they heat up again.
                Cranks and no start..could it be the ignition switch ?Im clueless?
                R.I.P
                F22A
                CAI
                Headers
                EXhaust
                  Hi, read my post above.
                    Thankx man I realy appreciate this. I been footbound for 2weeks because of this mess.
                    R.I.P
                    F22A
                    CAI
                    Headers
                    EXhaust
                      check the rotor in your dizzy. the screw dat holds it in place might of came off. dats happened to me before
                        I will do. Thankx for the help..
                        R.I.P
                        F22A
                        CAI
                        Headers
                        EXhaust
                          no problem. if dat is not ur problem just post again ill try to help as much as possible
