tranny problems
    tranny problems
    seldomly my car wont shift into gear... i can try to force it and keep trying, but it fails untill i turn the car off and restart it in gear??? does anybody have any suggestions on wat i can do?
    and yes i have changed the tranny fluid, and have topped up the clutch master fluid
    this is stumping me because i dont think its the actual tranny, im thinking it could be the linkages or the clutch slave cylinder
    oh i forgot to mention
    if i turn the car off and pop it into gear it will go.. then i can proceed with my journey, but i know its not the pressure plate or TO bearing like the other dudes post
      what kind of tranny fluid did you use in there?
      i hope it was honda mtf fluid or some 10w30 oil, but i would recommend you use the honda mtf found at any honda dealer
      Members Ride
        yeah
        honda MTF... and MTF only... unless Redline or Royal P are cheap which is a blue moon occasion
          check the linkage, make sure its tied doen at the tranny right above the vss, the bracket that holds the linkage
          Members Ride
            hoist
            fuk it... ill try it in the monrnin... i need a hoist and i can solve htis problem
              As blackcb7 said make sure its not binding. If not try bleeding the system a bit and see if it helps.
                make shure when you press the clutch in the clutch is disengaging if its not then adjust it. your car cant go into gear unless the clutch is disengaged(clutch pressed in)
