As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
EGR Blockoff
    EGR Blockoff
    Ok, I've tried four different EGR valves and I keep getting a EGR code. (and yes I reset my ECU). I'm simply fed up with it. How can I just disable/bypass the stupid thing? I know I can make a blockoff plate, but as long as my ECU thinks there's a problem with the EGR and throws a code it's going to screw up my air/fuel mixture correct? Is there some way to fool the ECU into thinking the EGR is there and working fine?
    I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
    "Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
    CB7: The Movie TEASER VIDEO
    chipped ecu (p06) - civics didnt have EGR so their ECU's dont check for it.
      id like to know this too...
      91 lx h22 ftw!!!1!!one!!
      lsd is wonderful
        have you try seeing if the valve closes when you rev up the motor high enough so that there is no vacuum suction to the valve??? You can rev the motor up at the thottle body and look at the egr it should close when u rev it high enough. If you tried 4 valves already, it could be a bad o2 sensors that saying your running rich and that may be telling your computer your egr valve is not working, but in fact it is working properly, so if you can swap that out with a friens o2 sensor, try that...if no, I do have a civic po6 ecu for sale, its standard tranny!
          well I DO have an aftermarket DENSO (I think) o2 sensor, don't know if this could be the cause of the problem. It definately doesn't throw any codes related to the o2 sensor.
