ok so i own a 90 lx previously bought from a mechanic and when it was bought i was told the car had been broken into twice with the deck stolen both times .... i got the car with no radio harness (due to the jackass who stole the deck) so i went to a junkyard picked up a harness and wired it up (from an exact model trim) everything is working properly except for the consistent power which i beleive is the yellow/red wire so when i turn my key everything restarts ... i know it isnt really a big deal but i enjoy the settings i have on the deck eg. radio memory, base, tilt etc. its annoying that i have to reset everything everytime i get into the car? .... i have tested every wire for the consistent power but nothing till i turn the key into ignition .... is there a fuse that i might need to change for consistent power? wire torn? OH YEAH AND MY CLOCK RESTARTS TOO it also flickers doesnt stay the same .... im guessing it has to do with consistent power aswell!!!!! help would be great guys trying to restore this cb to A++
problem with radio harness
check your fuses... theres a memory fuse that provides constant power to the clock and radio to remember the time and preset stations.
correct, check the fuse and stuff as mention, if you cant find it or cant make it work right and wanna run you own line, its easy. Just get like a 16guage wire and put a fuse at the end by the battery and run it to the stereo center console, now you will have the battery backup wire. Do put a fuse at the battery side end of the wire ok!
same problem
I have that exact same problem...before i got my 90 Accord LX, it had also been broken into and the harness was ripped out. The kid never told me but we (my fiance and I) figured it out after we took the stereo out of the dash to see why the speakers were staticy, thought maybe it was some loose wires in the dash, it's a total mess , looks like speghetti...no joke. we cant really find the right wires and because of this my front speakers and the door speakers don't work.
Now i do have a constant power source, from my battery, so my radio doesnt reset but my clock does. I can't put a 7.5 amp fuse in the back up radio (yes i've tried!!!) because of another problem i am having...the seatbelt light comes on and wont shut up..it constantly dings, even when the belts latched...i'm not really sure what to do here???????
To lxaccord
hey, I had the same exact problem when I finally dumped an aftermarket deck in my first 'Cord. I didn't have a fuse issue that I could find, so I just ran a wire behind the dash and into the steering wheel column and stole a constant off the little green light ring around the ignition keyhole. Sounds stupid, but it solved the problem, and all I needed was a 12" length of wire and a connector.
To myfirst CB etc......
don't know if this helps, but I got my deck install instructions off InstallDr.com, they had a full writeup for the 90-93 accord with some wiring schematics, might help you make sense of the spaghetti issueLast edited by qbodsyt; 11-13-2006, 08:33 AM.
