hey does anyone know about what the plm about distributor cuz i check about code 9 and it was ingition .... i did put new part and still not working and also module new part but still not working so it mean wire go to magnet somthing but no good??? cuz wont start and still crank but u think it was distributor right ??? let me know thank
distributor problem
dont jump to conclusions man, what are the chances that all 3 sensors are gunna go bad at once. Have you checked ign. coil. your ICM, and also and most importantly you main relay. >>>>> ithe igniton input has 2 go through the main relay before it reaches the ECU, becuase it acts as the coil side for the fuel pump.. check that out.-95 JDM H22 LSD-
-HYTECH Header-
-Skunk2 IM-
