So I am going to take my rims off and put the steelies back on for the winter. Do I need an alignment? Also probably in March, I will put the other rims on do I have to get another alignment for them too? Thanks
Wheel Alignments?
Exactly. The only issue you'll notice regarding wheels and alignment is that wider wheels will generally be affected more by a poor alignment. The alignment that killed the tires on my 17x7.5" wheels did almost nothing to the tires on my stock alloys. Wider tires seem to wear faster when the alignment isn't perfect (this goes for negative camber as well)
Originally posted by capman86what all does an alinment consist of do they move the tie rod ends or what else might be adjusted besides adjustable ball joints?
Thanks!
With an aftermarket kit, camber is adjustable through either the upper ball joint or anchor bolts.
I haven't seen any caster adjustments for the CB7; anyone know if they exist?Michael
Originally posted by LynkI haven't seen any caster adjustments for the CB7; anyone know if they exist?
It may be worth while if its never had an alignment. But as others said, tires won't affect it. Although when I switched on my 185s from my 205s, the misalignment felt worse. Put the winter tires on...if it doesn't feel right, then look into an alignment.
A four-wheel alignment made my CB feel like a new car No steering wheel movement, almost no vibration (even when braking, which I originally thought was wrapped rotors), much more neutral steering, tracks straight, and can generally can be driven with one finger. Much more confident driving it. I highly recommend a four-wheel alignment. Local dealership does front-end only for $50, and for another $20 does four wheel.Last edited by Otto; 12-13-2006, 01:50 AM.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Originally posted by nostringzwhat about tire size?
All that said, if you don't change the ride height of your car, and you keep your tires matched, then your modification doesn't require an alignment.Michael
Originally posted by 93cb7ExCoupeactually they say you should get a wheel alignment everytime you change either your tires, or wheels!!
its good practice to get a wheel alignment..
i have it done at least twice a year!
i hear you get an alignment every 6 months or every 2 oil changes (typically)
