bruno8747 is that turbo you got for sale for stock f22 what else would i need for complete setup how much more would i have to spend on like injectors and what not
Overheating fans?
Originally posted by MCimagthe radiator is about 6 months old the cap looks like crap woud that be the reason the fans do not come on and how can i tell if one of the switchs are bad
The cap has nothing to do with the fans coming on. A nice fresh cap will help leave your cooling system pressurized properly given that there no other leaks. It also ensures that air doesn't get into the cooling system. Air in cooling system is bad.
Replace the radiator cap as a maintenance thing. It's cheap.
ITS YOUR RELAYS! they're like 50bucks... just switch your power window relays with the cooling fan relays! --- they should work, they did for me. and your power windows may still work...
or its 50 or so dollars at Honda OEM ONLY! - checkers doesnt have them
im not sure tho because when i turned on a/c the fans turn on... i did thermostat also. but try the relay thing!
