its hard to get my car out or back into park on a auto tranny, what should i do or what is my problem
hard to get car into Park
i found out i had to do that same thing the other day when i installed the junk yard auto lever but i also cut off about a quarter of an inch on the black tab that slides up and down as you move the lever. i only did that because i thought it was too long and was hitting the shift linkage and it wouldn't go any further. also what kind of grease are you using? i used white lithium grease.
I replaced my transmission and had the same problem. I ended up adjusting the shift cable in the console to fix the problem. It was only a tad off but just enough to make it hard to shift from park or into park. Haynes manual has a pretty easy procedure to do the adjustment.07 Kia Sportage (Her car)
91 Accord EX (My car)
04 BMW R1150RS (My bike)
