grounding system
    grounding system
    i recently got the HKS Circle Earth Grounding System, and have not installed on my car because all the directions in the packaging are in japanese. im sure that its not that difficult to do to my car, but i wanted to make sure that there isnt anything that say not to do, or anything special that i have to do when i am installing it. does anyone here have or can get thier hands on directions in english? that would be of great assistance to me.
    93 Accord LX
    It should connect to you battery some way depending on what one you bought and the the frame on the car, then you should use the rest of the wires for the engine. One on the tranny, one on the valve cover, one on the head, one on the block, and just to be safe one on the thermostat. that should do it.
    -1991 Honda Accord LX H22a-
      yea, i figured thats how it gets connected, i just wanted to make sure that there were no warnings or things not to do when i was connecting it.
        connect one wire to each main piece in the engine bay.
        thermostat housing, vc, head, block, tranny, chassis (dont forget the chassis!!), etc
        the whole point of the grounding block is to tie everything in together with a solid, good ground, instead of a weak corroded ground. doesnt matter if something has a good positive connection, if the ground is weak/bad, it wont get good power.
