Suspension Clunk
    Suspension Clunk
    Whats Up well every time i hit a bump with my front drivers side tire i hear this clunk i dont think its the shock cause it rides real good no bounce and ya its the stock suspension i also hear this clunk from the same spot some times when i take of ans stop any ideas apreciated im leaning towards a bad strut
    Might wanna check your sway bar links if you have them, they like to break after they rust through. I had this happen on my SHO, sounded just like your are describing.....
      Make sure its not a loose brake rotor - they are not held on by the lug nuts - and if they are even slightly loose they can cause wierd noises...
        First check to make sure you are not missing one of the rubber sway bar bushings. Very common. Also would want to check and make sure you don't have a loose ball joint. Jack up the front wheel and try and move it back and forth as well and in and out. Shouldn't have any loose play or noise.
        1993 Honda Accord LX-auto--bone stock for now.--248K
        1997 Honda CRV--auto--bone stock--wife won't let me touch the CRV. 150K
        Need any performance parts? Check out my website or email me for prices.
        www.CARMandP.com
        Working on my H23 sway for free
          i agree, check sway bar end links...also check the sway bar bushings...they are not the same thing
          http://members.troublecodes.net/hond...20bushings.htm
