I just want to know where is the proper spot to connect the negative wire to in the trunk? And I also heard that you got to connect a negative wire from the engine block to the frame in replacement for the negative wire from the battery to the tranny, is this true?
Relocating battery to trunk
Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
-(B-Pillar Bar Originator)-Tags: None
Thank you! But, What does this External Shutoff Switch do and why do I need it?Originally posted by sensys01i just drilled a hole towards the lower bottom close to the back of the trunk. but keep in mind, if you plan on racing you will have to have an external shutoff switch. as for the negative wire to the frame i did this just for good practice.Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
Negative terminal in a way is ground. Zero voltage.Originally posted by cali-racerThank you! But, What does this External Shutoff Switch do and why do I need it?
It is a battery cut off switch. Search for what it looks like if you don't know but its basically a big switch that disconnects power from the battery with a flick of a switch.
Thank's Everyone!Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
