Heat not working
    Heat not working
    My fuse for the heat blew.. So i changed it and the heat is still not working. I checked all my fuses, none are blown.. Any suggestions??
    DA FASTEST ACCORD IN QNZ
    The H-series potential only begins where the B-series ends.
    83 Porsche 944 Black - Sold (my first)
    91 VW Jetta GL Red - Sold
    95 VW Jetta GLS VR6 swapped Green - Sold
    90 Accord EX 4dr Navy Blue - Sold
    91 Accord SE Gray - Stripped N Junked
    92 Accord 10th AE Green - Sold
    93 Accord LX 2dr Frost White - 4 sale
    90 Integra 2dr JDM B16 White - Sold
    93 Accord EX 4dr Black - New Toy
    Does the fan blow at all? If it does, have you checked your coolant fluid level? Does your car overheat? Are there any leaks? Another culprit could be the control valve, these things are made of plastic and get brittle over time.
      look sort of under the IM for a vlave conected to a hose that has a cable attached. selcet cold air, note the postion, then select warm and see if it moved. the heater core is feed from right next to the water pump Itself, so you should never have it run out of water supply. check the valve to make sure it is good.
      spin city
