Engine Wont Start
    Engine Wont Start
    i hav a problem i cant figure out y my car won't start when it is cold outside. i changed my battery, and got the starter tested and everything is good altenator is good also. any help would be kindly appreciated
    Check the main relay under the dashboard above your cruise control module on the driver side.
    -1991 Honda Accord LX H22a-
      well i changed the relay and the fuel pump about a year ago but it could be ill check it out
        we need some more info....like...is it cranking? or just sittin there clicking. also, if it is cranking...is it cranking quite easily or like a normal start. just a wee bit of ?'s.
        If you're gonna go, go with a smile!
        Current vehicles: 2006 Pacifica Touring Inferno Red (the Wife's) - 30k
        1993 Accord EX - optima 'red top' battery, magnaflow exhaust, tinted windows - My $500 ride w/ 217k miles
        2004 Suzuki GSXR750 - Racetech sus f/r. Dunlop Qualifiers. clear Puig DB screen. my drug - 7500 miles
          Its Cranking Regular It Just Dosn't Work Inthe Morning
            so are you getting fuel? are you getting sparks?
              maybe condensation if its happening in the morning...maybe water in the distributor cap? just a suggestion, and its only 2 screws to check.
              (\__/)
              (O.o )
              1991 Accord Ex Coupe:
              -RAI, New(ish) cylinder head, high power alternator (wtf )
              -Exhaust tip
              -DIY PCV Filter
              -DIY Oem Taillights
              Umm, yeah, my car needs some T L C
              People I've Purchased From: Kmart64,Yeamans17, (yournamehere )
                the ditributor is fine i checked the first morning it didnt want to start. later on when icame home from work i swaped bateries and bam it came on then the next morning it did the same thing and didint start
                  you could check the fuel pump relay
                    check your fuses.
                    ...adjust accordingly
