When i try to start my car, it takes a long time to crank, it turns over quite a bit before cranking up, but when it cranks up, it runs great, just wondering if its a weak coil? Need a Tune-up maybe? because the starter isnt going to last too long with it doing this....any help would be appreciated...
Need help...
it just turns over for a long time then starts, no sputter, it tries to start like one time thats it, then it just fires up but after a long time thats all....and when its running, no sputters no nothing, idles fine and everything...I like to ride simple and clean, with a "MONSTER" under the hood!!
yeah, i havent done anything to the engine, it may need a tune up and the wires do look kind of old and ill check the spark plugs too while im at it....I just went and turned the key, there is a hum so i dont think its the relay...so if a tune up doesnt help, then ill check the dizzy cap and rotor..thanks guys. Ill keep you guys posted....Im a newbie here thanks for the supportI like to ride simple and clean, with a "MONSTER" under the hood!!
