hey i was wondering if i have a f22 and want to swap to a 92-95 h22a1 what problems would i run into, like wireing or engine mounts or even space. would a cold air system from the f22 fit on a h22? if anybody could help that wopuld be great.
f22 to h22 conversion questions
your intake will work fine. the only thing with the mounts is the tranny mount. you have to tap 2 new wholes wich isnt very hard if you have the tools. and then the wiring. you got to wire in your vtec wich is 4 wires and you can find a diagram somewhere on here. and if your distributer is externel coil on the accords Orig motor then you can just need to connect to wires together to amke the new distributer work. its like a the yellow/black wire and yellow wire. just stick a fuse in the end of the plug and leave the black/white wire not connected to anything.
theres a swap guide on here that will tell you everything that will make more sense than what im tryin to explain.I won a game of connect four in only three moves
<br>
http://s80.photobucket.com/albums/j173/thisiskev6/car/?action=view¤t=stuffcar014.jpg
<br>
http://s80.photobucket.com/albums/j173/thisiskev6/car/?action=view¤t=stuffcar010.jpg
Actually i have an F22a6 and i was wondering if the h22 dohc head will bolt on with no problem's? please email me with all the details you can (derekclark85@yahoo.com thanks guy'swe ride for riding we drive for the passion we dont have money other's do .. we do this for the love of our car's ... we are ...Barcode
I have a good feeling that nobody is going to email you. If you don't have the dedication to spend a few minutes looking around this site for the answer (which is here... and yes, it will fit, but some modification of oil passages needs to be done, among some other things) then nobody is going to spoon feed you.
