temp gauge not working
    i have a 91 accord and my temp gauge just shoots straight up is there fuse or something that i could check to get it to work right.
    91 accord f20a still stock
    i would replace the thermostat....
      its the coolant temperature sending sensor has gone bad, its a little sensor under the distributor with one red wire in it, u have 2 change the sensor, i just had that problem like 2 weeks ago
      1990 Accord EX Sold
      1995 Accord LX V6 Stored
      1999 Accord LX Daily Driver
        i have replaced both of those and it still does it.
          i have the same problem what could this be?
          help us both i have this problem too
          lisa is long gone, but sophie is here!
          i got a good feeling about this one
          im going to have to
          __________________________
          |...OVERNIGHT PART'S 4RM....||'|";,__
          |..............JAPAN.................|| ---**-)
          |_..._...____________======||_|_|__--]
          check out my mr thread
          http://www.cb7tuner.com/vbb/showthread.php?t=106541
            dude, the car dont heat up, the temp guage just goes all the fuckin way to the H, and its pissing me off , i had to act before anything happend to my cb7, i replaced all the antifreez and its still doing that! wtf, its not cool man, i want to fix this problem asap, i searched but dont found nothing, but this thread, and i didnt want to open one and get it deleted bcuz its a repost ya dig, but my car is fine in all aspects, nothing is wrong with it, just that the temp guage goes up when i tur on the car
            im going to have to
              Its that temp sending unit. You sure you replaced them with the right ones. I forgot but I think fan switch and temp switch part numbers arent the same. But usually if it shoots up immediately and you know the motor cold the temp switch is bad. most of the time.
                so what should i get to fix the problem?
                im going to have to
                  bump i really need to fix this prob c'mon peepz
                  im going to have to
                    dude u probably replaced the wrong sensor, there are 4 sensors, theres 2 under the distributor but a single wire one under it with a red wire, that controls the temp guage, if it goes all the way 2 hot then the sensor is bad. replace that one, u should replace all 4 because they are all probably all gettin old, its not the coolant, if the car doesnt get warm change the thermostat too, and do a proper flush make sure there is no air in the system
                    1990 Accord EX Sold
                      aight thanx man
                      im going to have to
                        Myne Didnt Work Because Of a Grounding Problem.
                        "Black92Accord's NEW Acura TSX"
                        W/ Navi But Auto
                        SOLD
                        1992 Honda Accord EX 2dr. With a 5speed Manual Trans, Black Exterior with Black/Tan Interior
                        SOLD
                          http://www.cb7tuner.com/vbb/showthread.php?t=53982
                          .............................-----------------93 Ex Coupe[/COLOR]-----------------
                          My CD7
