I've read the sticky and searched all over the web for solutions to this surging idle problem, but I can't get it to go away. Any advice is certainly appreciated. Here's what's been done so far.
The car had a leaking radiator, so I replaced that. I replaced the lower and upper hoses, the radiator cap, and the thermostat. I've purged the coolant of air the best that I could, using the bleeder on the thermostat housing.
I've cleaned the idle air control valve and reinstalled it. Then I changed it with one from a junked car, but who knows if this one is good or not? I don't want to buy one from the dealership until I know for a fact that is the problem because a new one is $180.
I opened the FITV and turned the nylon ring clockwise until it bottomed out. This helped a little bit.
The hunting idle is better than it was and the car drives better than it did. It actually drives very well now, but the hunting idle is still there. 1100-1400 rpm. Once every blue moon (3 times since I've had the car) it will actually idle correctly when warm.
Thanks to all in advance!
