Ok.[sigh] Ive been tryin to solve this problem since last year. for those of you who care to take the time reading this you've prob never heard of anything like it.
[Most times when the weather is wet, damp, moist etc this happens.]
I start the car and D4 is always lit no matter what gear im in... sooooo when I turn it on im in P and D4 sooo when I go to reverse im in R and D4 and then when I put it in d4 I start out in the equivalent of 3rd gear (which as you know if u put ur car in 3rd as your 1st gear u will go NOOOO WHERE AT ALLLL)
So to start off I have to put the car in 1st (which means 1 and 4 are lit up)
1st gear is equivalent to the real 1st gear but 2 3 and 4 are all the same gear which is equivalent to 3rd.
So pretty much I have two gears (1st and 3rd)
Now ive replaced the transmission soooo I know it’s not the transmission that’s causing the problem...
Today ive taken out the TCU and looked at it and there is no corrosion, moisture, or any apparent problems with it. Sooo I put it back together and sealed all the cracks w/ silicon to make sure it’s not a moisture problem
Pretty much after the car has been running for like 10-15 mins the D4 will blink off and the shifter will make the same sound as when you press the break to go from P to any gear.
Ive taken the center console out and noticed it was a little box and it seems to have a magnet in it.... ive tried taking the box appart but it’s like u cant (no bolts or screws in it.) and u can’t really take it off because it’s attached to the plastic in the mechanizm
I do notice a ticking sound when the error is going away underneath the car of close to the cylenoids.... I couldn’t really pinpoint where exactly (making the sound it does when you press the break to shift out of P)
sooo really im at a standstill cause I cant diagnose the problem ... im pretty sure its spittin me a code but I don’t wanna go to the dealer and them b like oh welllll u gotta spend like 800$ to fix it...sooo if you’ve heard of this before or know a solution then feel free to give me insight.
Im sorry but I hate program cars... all the shit eventually breaks or like malfunctions... id rather a stripped down car and deff a stick, but of course only sunroofs, rear calipers, rims, etc. come stock on the luxery models (and its very rare to find a an EX or V6 4door in stick) but to make our car a manual it would cost 3k ( and I don’t have parts or labor people to get hookups from soooo yeah, don’t post about me converting, I would appreciate that, ty ^_^ )
