TDC sensor
    TDC sensor
    what is a top dead center sensor and where is it located???
    Sig removed due to excessive size
    Its inside the distrubitor. Chances are you need a new dizzy
      got one. what does the tdc sensor do though.
        Its to know when the engine is at top dead center to time when to fire the spark plugs.
          if the timing is off will it cause the dizzy not to fire???
            The timing at the dizzy or timing on the timing belt?
              either one, the problem is that i cant get any fire to the plugs and ive tried everything that i could think of.
                bump
                  So your problem is You are noting getting any spark at all?
                  Take one of the spark plug wires out an then take a spark plug and insert it into the wire, now ground the spark plug onto the engine and see if it sparks.
                  If it dosent spark, then you have dizzy problems or ignitior or coil pack problems. Next step would be to switch dizzy with known good working one.
                    i got a known working dizzy and still the problem persists. im stumped at this point. does anyone have any clue???
                      http://www.smpcorp.com/web_app/techt...824SPT2006.pdf
                      Read the second page where it talks about honda/acura ignition. It should be helpful.
                        thanks, this may just be my answer.
                          bump for any more advice.
