Have no idea
    Have no idea
    well im new here and there is a crazy thing bout the car it just makes me wonder ok i have a 92 cb7 lx and i start the car and there is a hmmm its like a spark plug ark off the crank pully maybe bout every 2 or 3 strokes of the motor its arkin off the pully like onto the body idk its crazy but and help would be great thanks
    no help yea must be noone has any idea either yea its kinda crazy and now my idle is messed up to it idles crazy with lights and stuff on but i shut it off it idles normal i have no idea any thoughts would be nice
      Check your grounds. THe only thing I understood out of this post was arcing from the crank pulley...
        TIMES 2
        either kill it or drift it...
        2002 Toyota Tundra V8
          Id have to say check grounds like stated above and make sure your plug wires are all clipped onto the plug correctly.
          Maybe one of your plug wires also has a cut in it. It will short out if it does.
          H22 Accord
            well what ground do u think it could be and where are they all located i can try and look but still if it dont have one on it then i would know where to look at and be able to tell right off they should all be in the same place
              Umm honestly I dont know any grounds toward the crank pulley lol. The one I remember on that side is fender to valve cover or something like that...You sure its not hitting anything.
                u mean the crank pully no its bout an inch from the fender yea i had a balance shaft seal go bad so i permed it in and after that it started doing the arc i dont know if its a sencer or what it could be its like a brain teaser but anyways now the car is just stalling like ill be going down the road and it will just stall out or if i come up to a stop idk what it could be
                  i had a bad ground i fixed it but it still does the same thing and the idle is messed up too when the heater is all the way up and my lights are on it the idle goes from 1000 to 1500 like loping then if i shut it all off it idles fine i dont know why but it just started doing that any help would be great
                    i fixed the spark problem i put a new ecu and dissy in it but now my problem is my car dies just out of the bluei can be driven and just die and even when i come to a stop it dies i read like alot of stuff bout it on here but they dont have the problem i have only when u drive it alot it just dies and then after i let it sit its fine maybe a few minutes then it runs like nothing ever happened its gettin spark when it dies i checked that out no cel it just dies whenever any help would be nice because im idk
