Engine stuttering/missing CEL 09
    Started yesterday at lower speeds, seems to really do it right at 30mph in 3rd gear @ light throttle but once in a while at highway speeds too.
    Initially it set no codes but after about 30 miles or so(my drive home from work) it finally set a code. CEL 09. I've been putting off a tune up for quite some time so I went ahead and replaced dis cap, rotor and plugs and reset the computer. Everything seemed ok. Drove to work this morning and it is still doing the stuttering/missing thing but not nearly as bad. No code though. any ideas?
    92 accord ex 5 speed
    I've gotten the code 9 before also. Its some kind of corrosion on the TDC sensor in the distributor. Take off the rotor and cap and spray brake cleaner all on the inside of the distributor and then blow it out well with compressed air. Use the "air in a can" stuff if you don't have access to an actual compressor.
      Thanks I'll give this a try today.
