i need some help figuring out how to disassemble my dizzy cause i need to put my f22 internals into my F20's cause my ckp and cps are badso please anyone help also i have a chilton but it doesn tell you anything
disassembling Dizzy help
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Not so DD 2013 Subaru Impreza WRX STI
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.Tags: None
cant help u much on this, bro.. im not that experienced in dizzy coils.. i have swapped the same F22 dizzy internals, but that was with guidance from my foreman..
pulling out the plastic rotor thingy was PITA, tho.. it was stuck, so i had to yank it out..
anyone else?
Click sig to view MR thread
Links to other rides:
Honda Accord Euro-R
Honda Odyssey Absolute
Honda City I-DSi
Honda Stream
lol yea i hear ya on the plactis rotor lol ive got all the screws out of it besides one by the wires down in there but that plate still wont come off grrrr
PSN ID's:Tidashoni
My FS Thread
Bump ....anyone?
PSN ID's:Tidashoni
My FS Thread
Unless you have very specific equipment and tools, you can't replace those two sensors.
The only things that are serviceable in that dizzy are the Coil and ignitor.
Even Helms doesn't provide instruction on how to do it.
The place that rebuilds them probably takes care of it.
Sorry dude. It is time for a new dizzy.
lol i got em apart
just had to pry the reluctor off and the plate poped off woot then all i had to do was pull them out the reluctor was a PITA tho
PSN ID's:Tidashoni
My FS Thread
its super easy to disassemble and replace the sensors inside.
remove cap, rotor, dust shield, and ignitor. there are two screws holding the top pickup coil and three screws holding the main plate and bearing, remove all 5. pull the snap ring off from around the rotor at the other end of the distributor and pull the pin out, which will let you take the rotor off. NOTE that it can go back on either direction - 180° off would cause serious issues, so make sure you mark which way it goes back on! if you forget, there is a way to tell, but i wont explain here. with the rotor off the tip and the insides loose, push the tip of the dizzy down onto a table and itll pop the shaft and plate up and out. the two remaining pickup coils are just held on by screws.
you can swap the set of 3 coils and their wiring as a whole, just make sure you use the proper F20 main shaft & bearing, while the F22 one would fit, it puts the outer rotor at the wrong angle.
thanks mike lol ill use that method on my f20 dizzy lol i guess i did it the hard way on my f22 lol im glad i dont gotta put the reluctor back on my f22 dizzy lol thanks again
PSN ID's:Tidashoni
My FS Thread
good luck man! good luck!
Honda Accord Euro-R
Honda City I-DSi
Honda Stream
thanks lol dangit i need a screw extractor now lol i stripped one of the screws out on the plate on the f22 dizzy lol so i gotta get that now
PSN ID's:Tidashoni
My FS Thread
yay ok so i got it all apart now just gotta put everything back in to the f20 dizzy i marked one side of the case to know which way to put it back on
PSN ID's:Tidashoni
My FS Thread
ok so im now putting it all back together and i can hear it ever so slightly hit one of the sensors when i spin it. is this ok or should i try and move it further away?
PSN ID's:Tidashoni
My FS Thread
adjust it man. u dun want any contact in that dizzy.. thats what happened to my F22B dizzy rotor..
Honda Accord Euro-R
Honda City I-DSi
Honda Stream
ok yay got the dizzy code banished lol they are no more. also i did adjust the sensors and nothing is touching so everything is strait but my car still wont run it fires up, goes to 1k rpm and dies
PSN ID's:Tidashoni
My FS Thread
daymm man.. i hate it when that happens.. can u sustain the revs with the throttle? wud it idle smoothly? F20B are hard to rectify man.. unlike the H22's..Originally posted by almostJDMok yay got the dizzy code banished lol they are no more. also i did adjust the sensors and nothing is touching so everything is strait but my car still wont run it fires up, goes to 1k rpm and dies
i'll make some calls to help u out man.. take it easy..
cheers
Honda Accord Euro-R
Honda City I-DSi
Honda Stream
