Calling All Ecu Tuners
    i bought a P06 ecu and tried the DIY Chrome basemap for an F226 engine...created about 10 different basemap and everytime i burn the chip and connect the ecu up to my car...another dissappointment after another...the check engine light stays lit and i can only rev the car up to 4500 RPMs...
    im using free Chrome software...27c512 chips...and the LS map...i have disable most sensors and such...but same problem occurs...
    my car mods are: K&N intake...4-2-1 headers, highflow cat, 2.25 pipe, and cherry bomb muffler...full MSD setup w/ SCI-ingnition...
    i was wondering if someone:
    1. can give me suggestions
    2. give me a basemap for a f226 engine
    yada yada yada...
    HELP ME!!!!!!!! THANKS
    A wise man sees failure as progress...
    whats ur email address and what burner are u using?
      james22187@yahoo.com
      i forget wat burner im using cuz i using the one at my electronics job...why...does it matter on wat burner u use???
        yes, it does. The burner has to have the ability to specifically program the 27c chips you are using.
        Another thing...why are you using 27c chips? They're only UV eraseable. Get yourself a SST chip from moates.net if your burner is compatible with it.
        map being sent now
          who'd you buy the ecu from?
          could be a bad soldering job.
            wow...thanks man...
            srry...i made a mistake on the chips...they are SST 27SF512 chips...and the burner at my job can burn those chip cuz its in its database...
              do you have the moates or the willems burner?(moates is the nice one in a black box and only 1 wire that connects to the computer)
                k, don't know how ur burner sets itself up but make sure u have that specific chip selected if you can. Come back with results, and yes it could also be a bad solder job or just incomplete.
                And please shrink ur sig down to the approved dimensions or i'll have to politely delete it
                  i bought it off of ebay...it was a stock ecu...i've mod the ecu myself...chances are..that the ecu is soldered ok...cuz i tried B16 basemap on a EG hatch civic with a P28 ecu and the same problem occurs...i think it could be the chips or the burner...
                    he may have one of those ginormous old skool ones...i know they do at my job
                      make sure you have the software updated and you are erasing and verifying the chips.
                      also, if you have the willems, make sure you have the correct dip switch settings thingy.
                      mrx can help you out more with that. i hate the damn willems.
                        i never even tried the willem with the SST chips, there were 2 different dip switch settings to just burn and erase it...so i bought me a moates instead lol.
                          yea i got one of those burner at my job...about 10years old or so...but the chip is in its database...after i burn the binary program to the chip...i alway verify the chip...
                            willems and moates are only the most popular in the car tuning world...theres a whooooooole nother slew of programmers out there tho. Since he said its at his job i bet its somethin we've never heard of
                            edit: yup, one of them big ass ones
                              haha, i hate the damn willems. I tried using phatdoughnuts once, it took me like an hour to figure it out
                              make sure that the rom editor window you are using is closed. nothing should be open except the program you are using to burn.
                              also, make sure you have the chip installed correctly. on the burner and ecu.
