I just got done swapping my stock f22a with a jdm h22a, but I'm having a problem. My valve cover to hood clearance is so minute that if I get on it, the valve cover is hitting my hood when it flexes. I'm wondering if anybody else has this problem and what solution is there to remedy this problem, other than cutting the structural support of the hood where it hits the valve cover. Any help or info is greatly apprecieated. Thank you.
Hood Clearance
Check your motor mounts. Mine is minute but its not bad. The only thing that fucked my hood was using the Accord PS pump.
ya.. either it rubs the hood on the valve cover or you put the oil pan so low that it drags. I had this problem on my swap but we made our own mounts and decided to make it like 1mm off the hood then take away from the hood supports alitle. Better than risking puting it lower and draggin the oil pan and bell housing. So, ya, you're gonna need to take alitle off the hood.
Why would you need to take a lil out of the hood? I ddidnt do that with mine...Anyway did you do the auto-manual swap by any chance? Also is your hood sitting flosh with the fenders? Because if it isnt it can cause a bit of a clearance issue. I can push my hood down about an inch and i will hit the vc on my motor. I dont see what damage it could do to it because 1. the hood is flimsy 2. you can prop the rear of the hood up a lil and it will give you enough clearance.
Its something to hold down the torquing of the motor so your motor mounts last slightly longer lol ha. Personally it doesnt bother me at all.Originally posted by trickedaccord92mine rubs too you can see it in my sig where the valve cover is getting rubbed but other than that i havent had any problems with it
that is the exact spot where my valve cover is rubbing with the hood.
nail05-the motor mounts are brand new, also what do you mean by the auto to manual swap? tensioner or tranny?JDM H22A LSD Powered 92 Accord
193.9 HP, 149.5 TQ
Skunk2 Pro Intake Manifold, Custom Header with 2.5in. mandrel bent exhuast
Accuracy Automotive-757-548-9227
Trans. Hmm mine doesnt look like its rubbing when i lift my hood. The only visible area I see rubbing was when I had my ps other than that nothing.
