H22a wiring help
    H22a wiring help
    Since i cant post in the regional section yet this will have to go here. I am in the process of wiring my h22 in my accord and im not gettin any spark or fuel. I have the FAQ but am not quite sure where all the plugs go, I have hooked up most of them but there are a few left over. If anyone in Texas in or around the DFW area would like to help it would be greatly appreciated. I can come and pick you up. My name is Marc and I can be reached at 817-899-8868 or owensmarc@gmail.com
    for just a little advice, mark every wire to where they go before u make any swap if u dont know the wiring by memory!
    Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
    -(B-Pillar Bar Originator)-
      I have hooked everything up now and changed the ignitor coil. Now everytime i go to start it it blows the ecu fuse. I checked all the grounds and there hooked up also.
        Make sure no wires grounding out around the ECU? When you wired it into the ECU plug make sure when you put the wire through the grommet you didnt accidentally cut a wire or so. Did you also wrap up the wires? But to follow the faq look on the p28. It is basically the same as the p13 for wiring wise. Just find those pins plug in and you should be fine.
          Thanks for the help guys I got it running this morning. I hope to be at the Texas cb7tuner meet this spring ill keep a watch on the regional section to see when it is.
            so wat was the problem?
              I had two of the plugs mixed up, as I was about to take off the harness I noticed it so I switched them and on the second try it started.
                lol nice.
