I have a 91 accord 2.2l with manual transmission. The other day I went out to drive it and it wouldn't start, the starter turns the engine over fine, but it never manages to get running. Recently it has warmed up from about 15 degrees to the mid 30s and we got a decent snow storm, so I'm thinking that some moisture got into the ignition system and its not getting spark, but Im not familiar with with that particular motor so I could be almost anything.
91 accord will not start
http://www.cb7tuner.com/vbb/showthread.php?t=2861
try that and check back first thing you got to find out is if your fuel pump is turning on.
when u put ur key into the on position the check engine light will come on and then go away, right when the light goes away you will hear a click...if you dont then ur main relay is bad.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
dont worry about moisture or anything like that. Unless you have no hood, Then you should..And uh try searching about your prob first..many of us have had this prob already and you shouldnt have any prob finding your answer..the search engine is up top in the blue bar.Originally posted by V3rtigoI have a 91 accord 2.2l with manual transmission. The other day I went out to drive it and it wouldn't start, the starter turns the engine over fine, but it never manages to get running. Recently it has warmed up from about 15 degrees to the mid 30s and we got a decent snow storm, so I'm thinking that some moisture got into the ignition system and its not getting spark, but Im not familiar with with that particular motor so I could be almost anything.
*Needs*
-New shocks
-Struts
-Drop
-Cleaning
-New Tires/Wheels
-New Window Tint
-Alot more lovin'
