0 gauge wire through passenger firewall?
    I was wondering if there is anyway it could happen? (i previously had a 4gauge running through)
    Yes it can pass through but you need to find the right place to snake the wire through.
    I ran 1/0 through the firewall and i used the hole above the ecu.
    Pull back the carpet on the passenger side floor. Now look above the ecu, there you will see a black plug/cap. Take out the cap and you will see stright through to the engine bay and the ground. Now drill a hole in the plastic cap and put the wire through.
      what does the ecu look like?
