Msd???
    Msd???
    im not asking how to install the coil, ive already got an external coil (93) it includes, distributer cap and rotor, and coil pack
    im asking if its worth the 100 bucks on ebay to buy it... is there signifigent increase in power, idle, electronic improvment????
    info please
    thanx,
    mike
    you won't see an increase in power, the stock ignition should be good up to 3 or 400hp. Its really only needed with different fuels and or big horsepower cars where more spark energy is required to jump the gap of the spark plug.
    nothing wrong with putting it on your car though, should get a little better mileage for around town driving and better throttle response. not sure which coil you are using, but i wouldn't recommend using anything other than an msd with an msd box.
    www.roskoracing.com << Euro-R manifolds/adapters and H22 parts
    >>check out my H23vtec build thread...
    http://www.honda-tech.com/zerothread?id=2030543
      If you're going to just get the coil/cap/rotor/wires, then just get the coil alone.
      You really cant get much better than the OEM cap and rotor.
      The coil is better than the OEM one.
      Also, if your current ignition system is up to par, then there is no reason to upgrade to an msd unit.
      MSD ignition units arent NEEDED until you actually start losing power b/c of your stock ignition system. (and that shouldnt be until you get some serious power)
