Well after my motor swap, I got the maintenance lite on , not the check engine. Also um my cluster is making a tick tick tick sound, like if i was using my turn signal. but stops when I use my turn signal but when it goes back to neutral position. It starts to tick tick tick. Randomly my speedometer will act up and my RPM meter will act up.
Any way to fix it? and my whole dash lights not working. But when u press the buttons they light up, but not the dash panels.
Final question Anyway to tweak my intake manifold without buying a new one. So it can stop idling. motor was OBD2 converted to OBD1. F20B SOHC VTec uses 3 sensor rather than two for OBD1. So my map sensor is not connected and stuff.
