timind belt question
    ok guys i have a 1990 accord dx automatic... i'm up for a timing belt change i'm already at 99k... the question is how do i know that my timing belt is bad? is there usually some warning signs before the thing actually snaps? i mean without visually inspecting it, i know it sounds lazy but i don't have a garage i could go and start removing things to inspect the belt......... thanx in advance...
    HONDAS RULE
    nothing you can do besides look at it. see if its starting to look worn.
    now i must warn you, not all belts look worn before breaking - its time has come, do the belt!!!
      you can inspect it by just removing the valve cover and the upper part of the t-belt cover.....you can see if it looks cracked...i personally woulndt wait though ...just do it or get it done.
      My Members Ride Thread
        you're definatly due for one, just go ahead and do it, the last thing you want is a snapped timing belt.
          Nope...no warning, no inspections. Thats why they say replace it every 90K miles or 6 years, whichever comes first.
          00 Jeep Grand Cherokee 4.7 V8 4X4
          92 Honda Accord LX
          95 Honda Civic CX
            ok guys now if i were to buy the timing belt and new water pump about how much would a mechanic charge for the labor.. i guess what i'm trying to ask is how much time is involved in swapping out the timing belt and water pump
              parts prices
              w pump
                well i called a Honda dealer and they said it would cost 700 dollars for them to do the timing belt. I also called an import mechanic shop just down the street, they said it would be 550 if they had to supply the parts and only 350 if i supplied the parts.
