Lucas Oil-I know ive seen this
    Alright I know I have seen a post like this before, but I couldn't find it now.
    Has anyone used it in an H22a, I know its really thick, I use it in my 92 Dakota but im worried to try it in a VTEC motor...any thoughts?
    H22a they always smile before Vtec....
    VIDEO WATCH ME!!!!
    My Members Ride Check It Out
    I would not recommend it because of it's thickness. H22's like Mobil1 synthetic
    SOLD!!
    Boosted H22
    375whp 298 ft/lbs at 15psi
      its a bandaid solution, right.
        LUcas is a big no go....
        http://www.bobistheoilguy.com/images/lucas/lucas.htm
          Originally posted by oozingmachismo2
          heres a quick note:
          if Lucas Oil Stabilizer creates air into the oil..why is it still on the shelves??
          on a personal note:
          it hasn't caused any problems to my engine...YET!
          it actually runs better...but looking at this link or website you provided..it does make me think if there is a "PATCH" for minor issues until you can tally up the funds to repair it!
          Oh well guess I'll just have to FLUSH out my engine when its time for an oil change and just use STRAIGHT Royal purple ..and fix the valve seals in my engine!!
          well...so much for an OIL SEAL BANDAID!
          LMAO
          MR Thread:
            I dont like running additives for that specific reason as someone posted the bobistheoilguy site. Its still on there because people dunno and dont see these tests. They just believe the commercials plus the lil spinny deal they have at auto parts stores you can turn it as fast as its going to be turnin in the engine. Plus thicker oil is not always better you have to keep in mind the Honda oil pickup and oil galleys are only a certain width. You put too thick of oil in there it wont run as efficient. So yea its your choice to run lucas. I wouldnt do it on an h22a. As long as you keep the seals and such maintained you should be fine and keep up with your oil changes with a good filter.
              Yeah, there are a lot of snake oils out there. When I did my last oil change, my engine was filthy even after I changed the oil because I had used greased lighting prior. Lucas fuel treatment is goodstuff though. Kenny, use this stuff called "restore".
              Its restores lost compression from pitted cylinder walls and bad valve seals. Its only temporary though(for valve seals). Its actually been proven to work by outside sources.Like bob the oil guy says, today's oils already have all the additives you will ever need. You just need to stay top of your routine oil changes.
                first off lucal oil stabalizer is not bad in honda motors, i use it after my oil changes. ur not supposed to use the whole bottle, ur supposed 2 use a quarter to half bottle per oil change. Its best used to restore engine performance because i have sticky valves and it works wonders with helping it. its something like engine restorer but it can be used in ur car long term. I dont think its bad to use, i still use it and me as well as many mechanics i kno would recommend it. i was actually told 2 use it by a mechanic
                1990 Accord EX Sold
                1995 Accord LX V6 Stored
                1999 Accord LX Daily Driver
                  anything thick in a honda doesnt sit well with me though, even the tranny fluid is thinner than other cars. I say used what the manual says.
                  If we're talking about doing good for the engine why not use seafoam instead?
                    True i see what you guys are saying, but the way you are supposed to add the this thick syrup additive is to mix it with 1/5 ratio oil, and that does break it down alot, almost to like 20w oil. I was just trying to see personal experience. After I added a little bit, my cam seals stopped leaking, so i was curious.
                    VIDEO WATCH ME!!!!
                      Seafoam is bad stuff. I would never recomend it to anyone. It does break Carbon deposits up, but I have seen way to many valve jobs at the shop after people have used the stuff, from stuck valves.
                      2002 WRX Wagon = My Baby
                      1993 CB7 Accord Ex Sedan = View it here
                        I use the Lucas fuel system treatment, the car seems to run better when its in the tank, and i get a few more km out of it as well
                          Hey oozingmachismo2,
                          Does that artical suggest that you use gear oil instead of lucas oil? Can you even use gear oil with motor oil, I don't know if gear oil has additives that can ruin engine seals.
                          I have use seafoam by running it through the engine by vacuum lines and it blew allot shit out, never really had a problem with that though.
                          I have never used their fuel treatment.
                          VIDEO WATCH ME!!!!
                            no,gear oil is wat too thick. Basically the article says oil additives are useless.
                            You oil that you buy from the parts store has alll the additives you will need.
