Upgrading to BIG 16g
    Hi. I currently have a 14b Turbo installed but want to reduce the chance of a blown engine but also getting more HP without modifying the internals. Ive heard that with the Big 16g, changing the internals is not needed just like the 14b. Is this true for the BIG 16g or would i have to upgrade the internals for this? also will the 14b exhaust manifold and dump pipe fit on the Big 16g? also, if Internals or other thing were needed, what would have to be changed or added? Please if anyone can get back to me on this before or by early morning tomorrow, i will be greatly appreciated. Thanks
    ,J.P.
    Justin Peralta
    Yes you can run the big 16g, It flows better than the 14b and produces less heat. Which is the enemy of FI. Just dont get boost happy with it.
      Thanks bruno8747
      Justin Peralta
        You'll most likely have to retune for the new turbo, though. Don't just put it on and run with the 14b map!
          O yeah. For shure thats a must. anyone have a map for this setup?
          Justin Peralta
            My 16g blew after lack of oil (damn oil restrictor)
            but after further research, as long as you have a decent FMIC, i'd just stick with the 14b.
            If you can, do some datalogging and see what your intake temps are. probably just fine...
            The 14b can handle about 260whp, for 8-10psi it is an absolute perfect match. Dont' spend your money on upgrading turbos if you plan to stay at this boost level.
            i plan on running 230-240whp at around 10-11psi.
            if your intercooler is 75% efficient, the difference in intake tempatures from a 50% (definate worst case senario on 14b), and a 70% 16g is about 10degrees :P
            there is wayyyy too much hype over turbo efficiency in the honda world...people saying the t3/t4 is the best solution
            definately not for this type of setup...
            at least come close to the HP limits of a turbo before moving on.
            If you want to upgrade, i'd recommend A) porting both the manifold and the turbo. ANd get a very good flowing exhaust.
            Also, in case you don't already, run some sort of intake pipe that pulls air in close to the battery...relocate battery to the trunk if you can (via marine box or gel cell).
            That's my rant for the day
