H22 swap need ecu??
    H22 swap need ecu??
    I'm in the market for an H22 in Georgia so first off if anyone knows a good source let me know.
    Additionally I know the stock Accord ecu can be used, but...do I need to have it tuned before I even drive the car with the H22 installed?
    Why would you want to use the stock accord ecu....
      first of all you need to check up some places for a motor. shit you could get it installed in your backyard and you dont need a garage to get it done.
      second you cant use the accord ecu. the h22 has 2 cams and the f22 has one. you need a ecu set for 2 cams + vtec. check up with mrx for a good ecu.
      miss my turbo cb7
        cams has nothing to do with why the f22 ecu wont run an h22.
          then whats up?
          miss my turbo cb7
            Internals are different other than some swappable parts and your sig is too big.
              im guesin the amount of fuel thats squirted in the stroke is different so when to fire i dunno.
                distributor controls timing.
                rockinricer is on the right track.
                  just get a p72 cuz ur car will run alot better than a p13 just wanted to let u know u are going stick right?
                    p72 is the gsr ecu. maybe chipped it will run better, but a stock p13 for a stock h22 is the best combo u can get.
                      a stock p72 will make your h22 run a lot leaner than it should, chipped ecu or stock p13 is the way to go.....
                      Retired 1990 Accord LX Coupe
                      Project 240SX
                        i have ran a stock p13 dyno and a stock p72 and the gsr ecu always maid more power!
                        if u dont belive do it ur self
                          im sure it did, but its also running lean meaning bad for the motor
                            go online look at the maps an youll see that the p72 will demand more fuel because of the smaller injectors so lean i dont think so...
                              my motor made 216 hp on a 12:1 air&fuel ratio a little lean for N/A
