hey whatsup i was wounderig what are some good companies for engine internals for the f22 thanks.
engine internals
F22parts.com is where i have gotten a lot of my parts for my f22 very good website. they can even grind camsOriginally posted by LiquidIC
GOT BOOST???
massive part out on accord almost everything is going
http://www.cb7tuner.com/vbb/showthread.php?t=125294
Well, if you want a higher redline, you'll need to improve the bottom end as well. Stock internals aren't made to rev higher than redline.
Headwork... well, you have your options open there. There are many good shops for that sort of thing. Just call around and find someone that's familiar with the F22!
Camshaft... go with a Delta regrind if you don't have much to spend. If you have a little more money, a Bisimoto camshaft is a better choice. Bisimoto is the best source for F22 performance parts, seeing as Bisi himself races an F22! Most other companies make F22 parts as an afterthought, just to grab what they can from the market.
Don't just slap on parts, though... put some planning into it. Do some reading (read any tech thread by HondaFan81... the man knows his stuff). You'll find yourself hurting performance, or only getting worthwhile power at an unreasonably high RPM if you don't do it right. 120whp with a wide powerband is better than 180whp from 6000rpm+
And in response to your sig... check out www.gear-speed.com for synchro kits and full rebuilds. h22sparkle can vouch for them... he's sent more than one transmission to them!
i got a head for my f22 made by gude or "bullfrog"- kinda expensive but had great all around power-customer service was kinda lacking but this was like atleast 5 years ago
Bought from: 92acclude, almostJDM, cali-racer, MikeW, rexload, slick, sackingz123, so-calsfinest, lindiz, yeamans17
Sold to: timmy0tool, sackingz123, judonoh, jdmhondaman, jdmaccord91,Ofr
mycb7.com
Members Ride
good parts
hey. i was looking all night for some all i could find on stricly accords were f22parts.com accordperformance.com those are the two main pages i found http://www.hondasociety.com/board/archive/index.php/f-9 these are also some good archives i found. i don't know if they will be any help to you but they have helped me out
later,
Chirsi~Christi~
the hell with hondasociety the booted me for nothing I WUV CB7tuner.com
