So i am gonna swap an h23 in my cb, couple of questions i couldn't find answers for.... h23 came out of an auto prelude and i wont to use my 5 spd tranny, will everthing line up ok, or will there have to be some mods? and i have the auto p14 will that work with a 5 spd? did some searching these are the only things i couldn't get answers to.
h23 swap
i would think there the same93 accord: F22A swap,T3/T4 turbo, tail wastegate, front mount 27x13x3, hks turbo timer, turbo xs boost controller, msd igintion, 3in downpipe, crane cam 11mm plug wires, denso plugs, no ac or ps,wire tuck, cutted insides, one seat, auto meter boost gauge,oil pressure, a/f,and 5 in tach,act clutch and flywheel.
93 prelude: jdm headlights,OEM carbon fiber hood, tein lowering springs, work racing rims with kumho tires, msd wires and denso plugs,type r shift boot
1. If you read the swap sticky you would know its a direct drop in and all you need to wire up is a knock sensor.
2. They had manual versions of the H23 they were NOT just auto.
3. And some searching would have told you H/F transaxles are interchangeable.
4. P14 works its the stock ECU.
well i have a chipped po6 that should work if i get a base map burned right???I have a p28 if not and thats gotta wrk...
I dnt have a chip burner, but i do have a paypal account and can send some1 funds if they can send me a base map burned on a chip!!!!!
I need chip (sst 27sf512) with h23a1 base map...
Shipped to 97405...
MIght wanna ask mrx/d112. And yes the p06 will work and if you get that you wont have to wire in the knock sensor.
