ecu interchange?
    ecu interchange?
    Which computers are interchangeble on Accords? Can 5spds swap with autos? What years will interchange?
    All USDM 90-93 Accords have similar ECUs. The EX ECU is slightly different, but it will work on an LX/DX. It'd be best if you swapped over the other EX parts, like the intake and exhaust manifolds, and the cam.
    I believe a 5 speed can run an auto ECU, but don't quote me on that... Somebody else would know that better than I would. I don't think you can run an auto on a 5 speed ECU, but again, I don't know for sure. The transmission is controlled by the TCU, so perhaps it wouldn't matter? I dunno...
    That's about it, unless you want to get into modifying ECUs. The P06 from the 92-95 Civic LX/DX is a popular and inexpensive choice, and is the primary ECU used by the turbo guys. The P72 and P28 are also common, but really only with the H22 swapped cars.
