help my cb7 is making noise on my passenger tire ..
    when i hit sertain speed and need to shifth gear it feels like my rim is loose, i check the balljoints and they look ok has anybody had this problem before...
    What speed. Check if your wheels are on tight.
      hey was up nail05 thanks for the clutch problem advice anyway i check the tire and is tight that was my guess but is not and u know ijust took all them balljoints off when i replce my clutch maybe theres something loose what do u think....
        hey was up nail05 thanks for the clutch problem advice anyway i check the tire and is tight that was my guess but is not and u know ijust took all them balljoints off when i replce my clutch maybe theres something loose what do u think....the speed maybe 20mph is makes the noise before i have to shifth so i been taking it slow
          my engine shakes when driving
          my cb7 engine shakes when i drive or i though it was comming from the passenger tire but when i raised both frnt tires in the air and open the hood i seen my whole engine shake could it be my motormouth or ball joints i installed e new engine on it now im having this litle problems also the bar that hooks under the car across the engine it not hook up coused for some reason my screws wont line up any comments of what the problem could be
            Mine felt like a wheel was loose (or bad tie rod), but the engine mounts keep the engine in line just fine. It was the front left lower ball joint that was bad. Causes bump steer, steering doesn't return to center well, etc.
            Might be a good idea to have a mechanic/technician check it out, that's what I had to do after I checked twice and couldn't find the problem (also hard cause I don't have a lift). Also had to have him fix it after I got frustrated with removing the knuckle and joint.
            Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
