evrything is new i have h22 swap new tranny alternator battery... was running fine all day yesterday till the end of the night ...somthing electrical is causeing the battery to drain any one else had this problom or know what is causeing this problom?? somtimes when i turn it i hear clicking noises in the dash if i turn on the head lights or the dome light it shuts off or if i press a button for the defrost sounds like i hear the clicking move under the carpet..i have no clue...also any one know what kinda money im gonna look forward on spending?? lol any help is very apriciated.
electrical probloms
well my first thoughts are what did u dissassemble in the car??
also all your ground wires are they hooked up under the hood?
did you add your new h22 wires the right way or just electrical tape them?
start with your fuses... see if any are blown.
check battery cables make sure they are fine
go to autozone and let them check the amprage on your car to see if maybe u have a bad cell in your battery or if your alternator is going out..
the clicking you are hearing may be from a fuse not getting enough power to work..
if it's not that then repost to meh"Self Renewed"
everything is new it is somthing with the electrical because it was hapining with my old engine in..wiring harness was professionally done by rywire ...dash lights and tail lights were not working before my friend fixed all that and i changed the battery twice. i was driving the car and i noticed the gauges stoped working then the dash lights started dimming and the car started pulling like it was running out of gas but the tank is full.Originally posted by Muffwell my first thoughts are what did u dissassemble in the car??
thenm when i was stoped the car wouldnt even turn and after sitting for a while it started to click and some lights would come on in the dash it seemed like when i put the key in i would get a clicking where the gauges are then i i press any of the buttons in my car the clicking would move throught the car
ok obviously the clicking is what all the instuments in the car do when they do not get enough amprage.. *basically your battery is dead! alright did you check the alternator??Originally posted by DAHONDACthenm when i was stoped the car wouldnt even turn and after sitting for a while it started to click and some lights would come on in the dash it seemed like when i put the key in i would get a clicking where the gauges are then i i press any of the buttons in my car the clicking would move throught the car
because when one of those go out they will drain your battery quick.. i dunno how i just know they do. secondly.. do you have any neon lights and such if so disconect everything except oem car electronics... also did you put in a new cd player.. opull it out and make sure their are no open wires.. check your fuses and make sure the right amprage is in the right spots so your car don't burn to the ground.. if you have a system un hook it... if after all this it does stop.. hook one iteam up at a time and drive so you can figure out whitch it is that is causing the problem. it sounds like an easy fix with the alternator to me. but if it's not that whew have fun finding those wires"Self Renewed"
