Dash Lights Out
    Dash Lights Out
    Ok so about 4 years ago I put white faced gauges into my gauge cluster when they were cool. My dad wired them into the same circuit as the dimmer so i could adjust them. Then like a few months later the dash lights ( cig lighter, HVAC contols, gauge cluster) went out on me. The white face gauges still worked so i said screw it. On the way home tonight my radio cut out (power wire loose and not fully mounted in there) so I did what i always do, pull the radio out a bit and push it back in. I know, I know not the smartest thing to do. But when I did it tonite the white gauges cut out. i know its a wiring issue but any ideas on what to test or try?
    Arcadia Green Crew Member #9
    ok, first you feel it would be wise to pull that radio out and un-break the problem... get the loose conection fix, then pull out that dimmer switch, and test it for contenuity* with a test light, and check your fuses under the dash, im also more then willing to bet theres a blown fuse in the fuse box under the hood... let me know what you come up with, and we'll take it from there.
    *sorry, cant spell for shit
